Cold spots?
Cold spots?
Postby dsm811 » Sat Oct 08, 2011 9:45 pm
If a wood floor is attached directly to the trailer and the floor is insulated between the trailers metal rails (underneath), will you get cold spots :snowstorm: on the wood floor over the metal rails?
dsm811
Re: Cold spots?
Postby halfdome, Danny » Sat Oct 08, 2011 10:34 pm
dsm811 wrote:If a wood floor is attached directly to the trailer and the floor is insulated between the trailers metal rails (underneath), will you get cold spots :snowstorm: on the wood floor over the metal rails?
I don't follow foamies but this would apply to any build. Your plywood floor will not transfer the cold through the plywood since it has an R value,
besides if you use a foam mattress not an air mattress it will insulate for you. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Wolffarmer » Sun Oct 09, 2011 1:22 am
Be sure to use foam for the mattress that will not completely compress and let you sleep on the wood floor. For several reasons. I replaced my original crap foam this summer with some much stiffer stuff from the Foam Factory.
Good stuff
I used the 5 inch stuff of that. I can stand on it with one foot and my 280 lbs will not compress it to the floor. I went a little over board on it. but it is much much better than sinking to the floor and trying to squirm about in a 5 inch deep foam lined hole. I think if I was to do it over I would go about 2 inch of this, then 2 inch of the next softer stuff.
Randy
Wolffarmer
Images: 309
