by Wolffarmer » Sun Oct 09, 2011 1:22 am
Be sure to use foam for the mattress that will not completely compress and let you sleep on the wood floor. For several reasons. I replaced my original crap foam this summer with some much stiffer stuff from the Foam Factory.
Good stuff
I used the 5 inch stuff of that. I can stand on it with one foot and my 280 lbs will not compress it to the floor. I went a little over board on it. but it is much much better than sinking to the floor and trying to squirm about in a 5 inch deep foam lined hole. I think if I was to do it over I would go about 2 inch of this, then 2 inch of the next softer stuff.
Randy
