by linuxmanxxx » Wed Jan 18, 2012 7:31 pm
For you Spec lovers out there (note it has the new freon about to become the new standard soon):
Name / Model # Climate Right Max / CR-7000
UPC Code 021251070000
SRP $599.00
Internet M.A.P. $579.00
Recommended Applications Work sheds, cabins, job site trailers, extra large pet duplexes, and more
Cooling Capacity 7000 btu
Heating Capacity 7500 btu
Dehumidifying Capacity 60% RH 0.20 gallon/hr
Power 115v/1hp/60Hz
Current 7.7a
Input power at startup 0.84kW
Room Coverage * 350 - 1,200 cu feet
Compressor Manufacturer Toshiba
Thermostat Digitial Display. Set to 61-87
Control Panel Digital. See Operating Manual
Unit Dimensions 20" L x 16.5 W x 14" H
Case Dimension (1 ea) 27" L x 19" W x 16" H
Hose Dimension
(2 hoses) 4.7" in Diameter, 39" L
Hole Saw Dimension
(1 pc) 4.5" in Diameter, 1.6" L
Couplers Dimension
(2 pcs) 4.5" in Diameter, 2" L
Clamps Dimension
(2 pcs) 4.7" in Diameter
Mesh Filter Dimension
(1 pc) 3" x 3"
Screws Dimension
(8 pcs) 0.16" x 0.32"
Foot
(4 pcs)
Drain Mouth
(1 pc) 0.16" in Diameter, 1.6" L
Weight 60 lb / 63 lb case
Hookup system Dual (2) Hose System (air intake/air outflow). Unit sits outside of enclosure. Accessory/Hookup Kit. Caster wheels
Assembly Kit ** Customized for wooden structures
Refrigerant R410a (New Regulatory compliant)
Air Filter Nylon Net
Noise 56db
Drain Pan included? No
Recommended Generator 1500W min (~900W est startup)
Replacement Parts? Yes. Coming Fall 2011
Color Off White
Operating Manual Included in box
Warranty 1 Year Limited Warranty
Technical Support/Troubleshooting 800-7-CLIMATE opt. 2
Outside lowest temperature 5 Degrees F
Outside highest temperature 109 Degrees FName / Model # Climate Right Max /
