Mike , I’m sure as with many materials ... you could make it work , maybe different configuration and fastening methods ? But on a properly built foamie , any wood would would be “encapsulated” and protected anyway , and even easily replaced if needed down the road... Not like you have to remove plywood , aluminum,or fiberglass ...
Just a few well placed cuts with a utility knife , remove the offending member, replace, glue in , cover & paint ... Bada Bing!!! Done ... You could do that at a campground too ... if the fish weren’t biting ..
