Tyvek glued to foam instead of canvas?
Postby kludge » Fri May 18, 2012 1:59 pm
Especially if you like white.
Just a thought.
kludge
Re: Tyvek glued to foam instead of canvas?
Postby wagondude » Fri May 18, 2012 9:30 pm
It has been mentioned, but no one has tested it yet. The biggest concern is what to use for adhesive. There was some thought that TB2 might not dry under tyvek and if it did, the tyvek might be too slick for a good bond. Mixed down foam in a can might do it. I haven't found anything that stuff won't stick to.
Bill
Bill
101137
wagondude
Images: 35
Postby kludge » Fri May 18, 2012 9:51 pm
For other applications I know some people are using 3M Super 77 spray adhesive.
kludge
Postby GuitarPhotog » Fri May 18, 2012 10:43 pm
I'll run a test tomorrow with some Fastbond 30. I'm sure I still have a tyvek floppy disk/cd envelope. :D
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby GPW » Sat May 19, 2012 8:08 am
JMHO, I don’t think Tyvek would offer the strength you’d need , unless it was really THICK ... :thinking:
Postby Wolffarmer » Sun May 20, 2012 12:15 am
I been waiting for some one to mention Tyvek.
Tyvek boat
Not much insulation, non really, but a wood framework and tyvek over it.
Randy
Wolffarmer
Images: 309
Postby loaderman » Sun May 20, 2012 1:46 am
The tyvek in the boat is the same as a tarp boat, strength is from the frame.
I thought about a frame and canvass/tarp camper. The made old plains like this
loaderman
Postby GPW » Sun May 20, 2012 5:14 am
3 layers , that could work ...?
