5x9 Hybrid
So, while I'm still waiting to gather funds for a build, I've been looking around at various other designs and comparing them to the ones I've posted.
While I like the simplicity of the 6x8 box design I posted, I'm still not sure how I feel about the overall looks of it. Some of the others who would be using it had expressed some similar thoughts as well.
So, I thought I'd go back to the drawing board and come up with something that is (hopefully) not too difficult for a first build but maybe a little less boxish.
So, after a lot of searching and tweaking, I came up with this 5x9 unit that I suppose you could call a TD, though perhaps not a traditional one.
I'm thinking the weight could be kept down by doing it as a foam hybrid.
Not quite sure what to use for the roof skin. I'm thinking canvas covered 1/8" ply, though.
I still don't think I need a permanent galley. We all seemed to agree on that. So, this unit doesn't have a proper hatch, which eliminates the always difficult task of keeping one from leaking.
Still, it might be good to have an area that I can cook on should I choose to.
An externally accessible storage area in the rear and a table that will attatch to the side.
The cargo area door may end up being a standard RV cargo door instead of a built one like it's drawn now. Can usually pick those up on Ebay fairly cheap.
The table could also be made to hold a permanent cook top and/or a sink.
On the inside you sleep facing the front of the trailer. Two decent sized interior storage areas above the cargo area with no worries about hitting your head when you sit up.
I like the idea of the door at the foot of the bed. I personally think it makes getting in and out easier.
Windows on both sides. Probably a vent or two in there someplace.
Sleeping space is 5' wide. 6-1/2' long. 4' high tapering down to 1-1/2' at the feet.
Storage areas are 2-1/2' deep, varying height.
So, now the questions.
First, general thoughts on the design are always welcome.
Second, if done as luan skinned foam for the walls and roof, should there be any problem keeping the weight of this down to under 1000 pounds?
