Free foam
Free foam
Postby Fishingtomatoseed » Mon Nov 19, 2012 9:09 pm
Seen this and thought about the fomie section........ if it can be used?????
http://dallas.craigslist.org/dal/zip/3411197536.html
Fishingtomatoseed
Images: 9
Re: Free foam
Postby GPW » Tue Nov 20, 2012 6:32 am
Free Foam is always Good .... underneath the aged exterior is good foam ... just waiting to be made into a foamie ... :thumbsup:
Re: Free foam
Postby jss06 » Tue Nov 20, 2012 7:00 am
That is from the dock that blew away during a storm this summer. A coworker had his boat there and it was on that dock. Luckily he had only minor damage to his. Others were not so lucky.
The only problem I would have is how to cut it to make it look nice. Although if it were a big enough block you could just carve it out and leave a shell.
jss06
Palladium Donating Member
Re: Free foam
Postby GPW » Tue Nov 20, 2012 7:44 am
Foam , being a homogeneous material , can easily be added to or subtracted from ... The foam blocks I bought were nasty on the outside , but pristine inside once sliced open with the Hot wire ...
For the price (Free), leaves plenty room for “experimentation" ... :thinking: 8)
