GPW wrote:Irv, we’re not quite sure what you mean by “ only Foam" and with 1/4” and 1/8” foam ??? seems rather thin to me , and with little insulating properties ...
GPW wrote:Thanks , yes, that would work !!! Sorry for the misinterpretation , I was thinking you were going to use the foam all by itself , which also works ...
GPW wrote:QUOTE: “ but I can't help but think it would be so fragile if it was only made out of foam! “ ...
Irving wrote:GPW wrote:Thanks , yes, that would work !!! Sorry for the misinterpretation , I was thinking you were going to use the foam all by itself , which also works ...
I realize that it's a well established building method on here.. but I can't help but think it would be so fragile if it was only made out of foam!
Perhaps I can get away with 1/8" plywood inside and outside with a 1.5" foam core.
eaglesdare wrote:Irving wrote:GPW wrote:Thanks , yes, that would work !!! Sorry for the misinterpretation , I was thinking you were going to use the foam all by itself , which also works ...
I just want to let you know that foamies are not fragile.
GPW wrote:Irv, we make a lot of silly faces here, think nothing of it .... if we were talking directly , I’d still make silly faces as well ...![]()
Did you read the BIG thread ??? That’s the initiation around here, just so we can all talk on the same level of knowledge and information ... Highly SuggestedAll this has been thoroughly tested, and re-tested , with tens of thousands of miles under their wheels ...
