What wood size for extending bed off trailer for "foamie"
Hi all!
I realized after all I typed below...I may not have been clear on my Q...What is the minimum I need in order to widen and extend off of the trailer, in terms of lumber?
ALSO, can you use the "magic mix" of min-spirits and poly on pressure-treated wood?
I just spent a couple of days completely gutting a 1970's Coleman Popup to get down to the trailer and cut off some of the outside edge metal for weight...now it is just under 300lbs (I used 3 bathroom scales to determine this). I don't want to be restricted to the narrower dimensions between the wheels and don't mind losing a little cabin space to the wheel-wells/fenders. So, similar to OHBUGGER who added side-to-side lumber (2x2's and one 2x4?) on a HF trailer, then used rolled peel and still window flashing (in lieu of black goo)..and then mounted ply to that. See also: viewtopic.php?t=45827
I'll try to put pics in here...and see if they work out to show you:
IF you can see the image I grabbed from FaceBook where I posted it and I think it is public...this shows the old (HEAVY) subfloor in mid demo:
https://www.facebook.com/photo.php?fbid ... =1&theater
THIS ONE shows the frame I had before I cleaned it and chopped a bit off:
And this one is after I chopped off the extra metal (maybe I shouldn't have?) and ground off rust and primed/painted it:
IF THESE AREN'T VISIBLE OR CAN'T BE LINKED TO....then I'll at least post my Q for now and learn (re-learn) how to get them right in here!
---->>>>Also, Thank you in advance for any help! I have been lurking here for a while and there is SOOOO much great info (and people). And yes, I have begun reading "the big thread" (up to 396pages as of today?) and I find myself getting lost in it.
