Attachment method to frame?
I'm curious about what those of you who're building foamies have done to attach to the frame? What method, by what means?
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
jseyfert3 wrote:You mean attaching the floor to the frame? Or the walls to the floor?
mdk wrote:jseyfert3 wrote:You mean attaching the floor to the frame? Or the walls to the floor?
By the frame, I mean, the metal part your axle and tongue are attached to... and by attachment, I mean whatever you used... bolting, gluing, welding, etc.
I have done a lot of looking at builds, and rarely do people say in detail how they attached, and even more rarely do they take pictures
So, I thought it might be interesting, especially for the foamie crowd, to see what they did in terms of frame attachment. I've been pondering that for some time now, and have yet to come up with any ideas that I think are not just good, but foolproof and the strongest it can be.
jseyfert3 wrote:One thing I haven't come across yet, is attaching a raised floor. If you make a raised floor frame from 1x4's, how do you bolt that down? Metal angle brackets, that bolt to the frame then to the 1x4? Seems like you couldn't drill through a 1x4 and run a long bolt through it lengthwise. Perhaps you could, or maybe lag bolts? But it seems lag bolts could have a problem with rotting near the threads, plug again not much room drilling into the narrow edge of a 1x4. I did look for this, but haven't found it. Seen a couple raised floors, but when I did, they didn't say how they attached it to the trailer.
grantstew8 wrote:JS that is ingenious, using hangers ...brilliant!
