KCStudly wrote:http://www.bigduckcanvas.com/10-oz-cotton-duck/by-the-yard/10oz-72-canvas-natural/
You will probably need more but when ordering less than 9 yds their default is to fold it; if you ask they will roll it. 10 yds and up will be rolled; less creases that way.
mikeschn wrote:Big Duck it is. Gonna place the order this evening... 10oz!!! Mike...
Fred Trout wrote:mikeschn wrote:Big Duck it is. Gonna place the order this evening... 10oz!!! Mike...
HF tarps have many pulls, pills, and flaws of all kinds as you can see in my photos but they all buff out![]()
Worked fine for my build except for the roof compromise but it was ok.
can I remove those pills after a few coats
Fred Trout wrote:can I remove those pills after a few coats
You might have noticed in a few of my pix, the worst pulls & pills have a dab or two of TB II on them. That is so the canvas stays stabilized when I sand them off even with the rest of the weave, so we will find out. I will be using normal dry wall mud techniques to remove overlap lines and other imperfections, smoothing out the weave as much as possible on my build starting after the first primer coat of cement & block paint.
I see no reason why sanding off the pills & pulls should not be OK but never done it before. The TB II on both sides should stabilize any possible unraveling.
