Cutting Foam with Tile Saw
Postby 8 » Sun Jul 26, 2015 12:29 pm
I was cutting some bead board foam a few days ago with a knife and the edge was coming out really rough. My tile wet saw was sitting there and I tried it out (without water). It makes a perfect clean cut. So, today when I was cutting some more foam, I just stuck the tile diamond blade into a circular saw and used that. No mess. The beads seem to melt a little and seal the cut edge. The only problem is that it is a hand held saw. Next I'll see if the blade will fit in my table saw so I can use a fence and get a straighter cut.
It's not fun and games until someone loses an eye.
Visit my blog ... http://www.64ox.com
Re: Cutting Foam with Tile Saw
Postby dales133 » Sun Jul 26, 2015 12:43 pm
It should fit an angle grinder too.
I use my 5 inch grinder for cutti g tiles
dales133
Postby lrrowe » Sun Jul 26, 2015 4:34 pm
I have had very good success with my table saw and the regular wood cutting blade for EPS foam. I do not know if that is a fair comparison. The only problem I have is holding a 4' by 8' sheet steady. Otherwise it bucks back on me and tears up the cut edge.
Bob
lrrowe
Images: 439
Users browsing this forum: jgmahoney and 6 guests
