Wet-and-Stick Fiberglass Fabric Tape
Postby KCStudly » Wed Aug 12, 2015 12:40 pm
Ran across this today:
Wet-and-Stick Fiberglass Fabric Strip
.035" Thick, 4" Width
Available Lengths, ft. 10, 25, 50, 100
Thickness 0.035"
Width 1, 2, 3, 4 or 6 inches
Additional Specifications:
Strips, Similar to plaster, this adhesive-impregnated material becomes moldable when water is added and hardens as it dries to meet your sealing, insulating, and covering needs. Maximum temperature is 1100° F. Color is off-white.
Price ranges from $0.61 to $1.27/ft depending on width.
http://www.mcmaster.com/#fiberglass-tape/=ygrk8f
:thinking:
Re: Wet-and-Stick Fiberglass Fabric Tape
Postby lrrowe » Wed Aug 12, 2015 1:55 pm
Thanks for posting this. I see a few applications already that I can consider using this tape on.
I have the site bookmarked.
Bob
lrrowe
Images: 439
Postby KCStudly » Wed Aug 12, 2015 2:25 pm
I suspect that it may dry brittle like plaster, as per their description, rather than rigid or flexible, but I thought it might be worth tossing it out there. Probably not something to consider for structural use, but may have a purpose for our use in some other way(?). :thinking:
Postby GPW » Wed Aug 12, 2015 3:29 pm
Maybe a small test sample ?? :thinking:
Postby angib » Wed Aug 12, 2015 3:57 pm
Bear in mind that there is a big difference between glass fibers and fiberglass. Fiberglass usually means glass fibres in a resin matrix that makes a strong, light material. Lots of materials have glass fibres added to them to make them a bit stronger.
The fact this is 'activated' by water rules out any resin since all the common ones won't cure right in the presence of water.
This tape may have many valuable uses*, but I doubt sealing trailer bodies is one of them.
* Sealing a leaky snake oil container, for instance?
angib
5000 Club
5000 Club
Images: 231
Postby KCStudly » Wed Aug 12, 2015 8:19 pm
Yup. Like I said, I had not seen this before and probably not for structural use.
Just thought I'd throw it out there and see if any one has any experience with it.
Postby GPW » Fri Aug 14, 2015 7:23 am
KC, we saw some stuff called magic plastic of something like that. Crystals when put in water , softened into a shapeable mass of ... plastic .... when dry it dried like ... plastic ... Some fiberglass tape imbedded with something like that would theoretically be super for doing edges and corners ... And with the thought that TB2 works so very well with glass cloth (tested) , that provides a “wet-and-stick” method we can do right now ... Saturate the tape in a tub of TB2 and stick it down to the surface intended. :thinking:
Postby KCStudly » Fri Aug 14, 2015 8:00 am
So right you are.
Like I said, it was a curiosity I happened upon. :D
Postby dales133 » Fri Aug 14, 2015 8:05 am
That kneadit style epoxy stuff could be good for corner oppsies.
Has anyone used tb2 over body filler?
dales133
Postby GPW » Fri Aug 14, 2015 10:18 am
Dale ,I think TB2 needs a porous surface ... or maybe something with a good “tooth” ... :thinking: (That’s another thing to be tested )
Postby KCStudly » Fri Aug 14, 2015 12:06 pm
TB2 does not stick to Bondo well.
Postby cpinetree » Tue Nov 24, 2015 8:32 pm
KCStudly wrote:Ran across this today:
Looks like it may be the same stuff a cast is made with. When my son had a fiberglass cast, they soaked it in water before wrapping his wrist.
3m casting products:
http://products3.3m.com/catalog/ca/en001/healthcare/-/node_GSFZV99RJVbe/root_VJ3G0N3T7Ngv/vroot_3LPG2VJGS7ge/gvel_NL72KXQND0gl/theme_ca_en_healthcare_3_0/command_AbcPageHandler/output_html
One of the products on that page - The soft casting tape, states:
A fiberglass casting tape which does not set to a completely rigid state, but remains flexible and soft even when it is completely cured.
I was tempted at the time to ask for a roll, but didn't :(
cpinetree
Images: 18
Postby KCStudly » Tue Nov 24, 2015 8:39 pm
Very interesting! :thumbsup:
Users browsing this forum: Google [Bot], jgmahoney and 13 guests
