Storage and Flooring Concerns; Suggestions Please?
The trailer I'm using for my first build has 10" high railing around the three sides of the perimeter. I want to use this space for storage. I initially thought I could use 1" foam board to make the box that would fit inside this portion. The tear drop floor would sit on top and across the rails (interior measurements 60"x96"; with rails it's 65"x98"). To gain access to the storage space I wanted to put in floor hatches in the floor in two places; one near the door and the second toward the bulkhead. I will use what I cut out to cover the openings and add supports from underneath.
Since I can't get ONE sheet of plywood to fit, I"m going to have to cut multiple pieces. My concerns are this: Will there be enough support with the plywood alone after cutting out the access, to support two people sleeping? What thickness would be my best option? Or would framing in the storage with wood, foam board and crossbeams be a better solution? My third thought was to just pitch the foam board basement idea and build the basement entirely out of wood.
Thanks!
Thanks!
