Cutting a hole in skinned foam
Postby Don L. » Wed Feb 03, 2016 10:14 pm
I am up to page 380 and have a question I haven't seen yet, maybe someone can answer it. Say I want to cut a square hole in a canvas skinned foam wall and I want to do it very cleanly, any ideas?
I can imagine a sawzall would look pretty rough. Electric knife?
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Re: Cutting a hole in skinned foam
Postby GPW » Thu Feb 04, 2016 8:09 am
Cheap serrated steak knife works great with a sawing motion , just be careful take your time ... You might want to see how it works on some scrap foam first ...
Ps. Worked so well , we included a serrated steak knife in our Foamie repair kit ... ;)
Postby Pmullen503 » Thu Feb 04, 2016 8:47 am
I would pre-cut the canvas with a utility knife and then saw out the foam. I think you would get a cleaner edge to your opening.
Pmullen503
Images: 67
Postby tac422 » Thu Feb 04, 2016 11:59 am
I drew where I wanted the opening and cut an X pattern, then peeled the canvas back.
I used a razor knife to get a square cut and removed the just the foam leaving the canvas intact on the other side. Then I cut an X pattern in the outer canvas, and wrapped and glued both the inner and outer canvas over the newly exposed foam to seal everything up.
122125
The picture above is the door frame setting in position with the foam removed and the back canvas uncut.
122153
tac422
Postby Pmullen503 » Fri Feb 05, 2016 8:47 am
Nice!
Pmullen503
Images: 67
Postby Don L. » Sat Feb 06, 2016 10:40 am
Good suggestions! I'm planning on cutting out the door and windows after both sides are skinned, primed too I guess. I found a source for used camper windows and doors, reasonably cheap, which I plan on going to get some next weekend. I'm hoping for some jalousie windows.
I am still reading and not much working although today I plan to sand and prime the trailer chassis.
Don L.
Postby rowerwet » Sun Feb 07, 2016 8:16 am
I use a razor knife on the canvas, for foam nothing I've tried beat a a hand drywall saw
rowerwet
Images: 521
Users browsing this forum: jgmahoney and 7 guests
