Ideally, I would like to build a 6x10, 6.5' standing foamie, probably a simple box shape. I had a 4x8 that was 5 foot tall and it was a little too small. My design goal is a simple design that can be built quickly. I would like to haul it with my 4 cylinder car with max trailer capacity of 1,000 lbs, 100lbs tongue weight. I don't necessarily need to use this trailer but if it could be done with this trailer it would save a lot of cash.
Do you think a foamie of this size will come in under 600lbs? Or better said, under 450lbs, leaving me some room for gear weight?
The width of the trailer is 52", from outside of tire to outside of tire. How wide do you think one could build a foamie with this width?
What size foamie do you think would fit on this narrow trailer with limited load capacity?
