Hi All,
For those living in the frozen northern regions, 1-1/2" and 2" thick foam seems to be stock items at Home Depots and Lowes. In this area, they don't and if you ask, they either laugh at you or give you a blank stare.
For your information and lots of calling around, I found a few places that carry XPS polystyrene foam sheets thicker than 3/4". Roofing supply dealers here only carry poly-iso foam (urethane) which would be dodgy for anything but a stationary trailer. However, one dealer did suggest I call a couple of "Damp-proofing" suppliers he named. Who would have thunk?
As of this date, All-Tex Supply (512) 837-0977 carries both Dow brand Styrofoam Scoreboard (the blue stuff) and Owen Corning Formular (pink stuff) in 1", 1-1/2" and 2" 4'x8' sheets. Both are 25 psi boards which are 1.5 lb/cu-ft foam. Prices for the DOW brand (blue stuff) are $2.00/sq-ft for the 2", $1.50/sq-ft for the 1-1/2". Owen Corning (pink stuff) prices are a little cheaper @ $1.80/sq-ft for the 2" and $1.35/sq-ft for the 1-1/2". Not sure (I didn't ask) but those prices are probably before tax.
The other supplier is SSI Commercial & Highway Construction Materials (512) 326-1156. I would have never though they carried foam board. They only carried the Dow (blue stuff) Scoreboard in 1", 1-1/2" and 2" thicknesses. Prices are (sales tax included) $25.84, $38.45 and $51.58 respectively. The scores are shallow (<1/8") and are intended for snapping the foam at 16" and 24" centers (std building dimensions). Both suppliers will sell individual sheets, not a full pallet !
I did find another couple of suppliers, but they would only sell pallet loads. One did say they might find one of their suppliers that may have fewer sheets they might be able to get.
For my project, I'll need 10+ sheets which is a substantial outlay for just the foam. If I only wanted 1-1/2" foam, I could laminate 3/4" sheets from Home Depots or Lowes for slightly less (2x ~$15 +tax) but then there is the cost of the glue to laminate them. A foamie here is not necessarily a thrifty alternative.
-- Teri
