There was a Fiberglassed Foamie before that .... Guy named Glassice made it , then disappeared..
Postby GPW » Mon Oct 16, 2006 8:17 am
It's kinda' obvious from all this that a F/ glass' TD is a serious undertaking ....and from the tribulations that glass' has gone through , and all the materials he has used , it 's also not cheap ...or easy .... Boatbuilders are bemused!!!!.... The thing to do is make a mould, like one for building a boat hull (TD cabin shell , no floor ) either spray (CG) or hand lay up material ... time consuming and messy . insert foam walls etc, (flotation ) f/g over the foam ...or use interior mould for "finished" appearance... Basic FG boatbuilding 101... Not Cheap or easy .... all phases require experience in material handling and application ...not really for the homebuilder.... unless you're gonna' make a bunch of them ....
Yes the Bub was the first sorta’ practical Foamie , and didn’t it Float too ... It all seemed like a good idea ,maybe a little overbuilt (from what we know now)
Makes one think one like that now built with a sturdy base and light roof wouldn’t need any “mechanical lifters ” , just a couple strong arms ...
As they say , everything comes full circle .... How about a redesign or the Bub into a SUPER BUB !!!
Users browsing this forum: Google [Bot] and 13 guests
