Mounting floor to frame
Postby rustytoolss » Sat Aug 06, 2016 3:01 pm
Is there any reason why you should not mount your floor material directly onto frame, with out using a wooden spacers ?
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Mounting floor to frame
Postby bonnie » Sat Aug 06, 2016 3:03 pm
Nope. I'm using just canvas and foam in my new floor. The top most layer will be a piece of nice vinyl. All held together with bolts and washers
Remember, the turtle won. :)
bonnie
Images: 107
Postby ghcoe » Sun Aug 07, 2016 3:39 pm
Only thing I can think is that it could create a moisture trap. With metal against the floor it could create a rot issue. I was going to mount the floor directly to the frame, but have since decided to install a 2"x2" piece of wood between for a spacer. It could be a sacrificial piece if need be. I plan on finishing the bottom of the floor with roof sealer. Then install the 2x2 and caulk all edges to the floor to keep moisture out of that contact area. Then cover 2"x2" with roof sealer. Then mount to trailer frame. I could use a 1"x2", but decided I wanted a bit extra height on the trailer to allow a bit more clearance in the wheel wells.
Good luck.
George.
ghcoe
Postby rustytoolss » Tue Aug 09, 2016 10:55 am
What kind of plywood did you use for the floor (exterior grade/ pressure treated/ regular/marine grade ) ?
rustytoolss
Postby ghcoe » Tue Aug 09, 2016 7:42 pm
I used OSB on my build.
George.
ghcoe
Users browsing this forum: jgmahoney and 16 guests
