rustytoolss wrote:VijayGupta wrote:How much Gorilla Glue to buy?
None. Hate the stuff.
so what are you using ?
Let's see the pros and cons of Gorilla (polyurethane) Glue vs. a Type-II PVA like Titebond III
Cons:
* Short shelf life
* Expensive (even more expensive if it cures in the bottle and you throw half of it away)
* Foams
* Extremely weak in thicker glue lines (need to have a very well-fitting joint)
* Stains the skin
* Repeated exposure can lead to sensitivity
* Longer clamp time
Pros
* Water resistant
* Longer open working time
Franklin International, who also make their own polyurethane glue, says this in their FAQ section of their web site:
How does Titebond III compare to polyurethane glues?While polyurethane glues bond well to a variety of materials, Titebond III is superior in many ways. In addition to excellent water-resistance, it provides a stronger bond on wood-to-wood applications, doesn't foam and requires less clamp time. Titebond III has no health issues, doesn't require the use of gloves and cleans up with water. It is significantly less expensive than polyurethane glues and offers similar coverage rates.
