Foam what to buy ?
Foam what to buy ?
Postby rustytoolss » Thu Oct 06, 2016 8:48 pm
I want to buy my foam soon. Can you post from best to worst foam to use . I wanted XPS. But might not be able to get that. What would be the next best ?
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Foam what to buy ?
Postby GPW » Fri Oct 07, 2016 6:03 am
RT, the FoamStream is made of the beaded type foam ...That works and can usually be found in many different densities , and prices (cheaper than Blu/Pink/green foam )
The foam you don’t want is the Tan crumbly foam ... just too brittle and emits toxic (gas) if heated ...
Postby rustytoolss » Fri Oct 07, 2016 9:11 am
So those are my two best choices (XPS & beaded) ?
Question ; Can I mix different colors of XPS? Will they glue OK ? Also Can I mix XPS an Beaded ? will they glue OK ? just asking. I was planning to buy XPS from a foam reclaimer in Akron, Ohio. But right now he does not have XPS. :cry:
rustytoolss
Postby KCStudly » Fri Oct 07, 2016 9:52 am
Yes and yes.
Postby rustytoolss » Fri Oct 07, 2016 8:46 pm
EPS is the beaded type..right ?
rustytoolss
Postby GPW » Sat Oct 08, 2016 6:15 am
Rus, You can mix both eXtruded and Expanded foams as you like . ( just not the crumbly foams) And the rule for us is, when in doubt about the foam strength make it Thicker ... because twice as thick is EIGHT times as strong ... !!!
Postby Andrew Herrick » Sat Oct 08, 2016 1:23 pm
From Worst to Best (in my opinion):
- Double Bubble Foil-Faced Insulation: I can rant about this stuff all day, but here's the short version: This stuff, which goes by trade names like Reflectix, does not insulate like foams! It operates on completely different physical principles, and generally, the R-value on the retail packaging is wrong. And, in teardrop terms, it's crazy expensive for the performance you actually get.
- EPS: Extruded Polystyrene (beaded coffee cup stuff). It has the worst R-value across temperatures, it is bendy but brittle, crushes easily and water can get trapped between the little beads. Now, if you find a high-density EPS, ignore most of these problems. Also, lots of people use a version called R-Tech, which is foil-faced and seems to work much better. The cheap stuff is yucky to kerf.
- Polyisocyanurate: The "tan and crumbly stuff." Yes, it's brittle, but it's also very strong and has the best R-value at warm temperatures (mediocre performance in cold weather, though). It is also the most toxic and most flammable. It will also absorb water, which is why it's always sold with a foil face (which, by the way, does NOTHING TO IMPROVE INSULATION in teardrop applications. Big pet peeve of mine. :x ) Also the most expensive. Difficult to glue because of the foil face.
- Extruded polystyrene (XPS). Great R-value, strong, flexible, elastic, easy to cut and easy to glue. My personal favorite.
P.S. As you probably know, lots of glues, particularly the ones that air dry, don't work well with foam. I've had better luck with spray-on adhesives from 3M, like Super 77. Other people like Gorilla Glue.
And to add to GPW's comment about 2x the thickness being 8x as strong ... that's true ... only if you're loading the foam in bending. Not true, for instance, for foam in your walls.
Good luck with your project!
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
