Page 1 of 1
Wall thickness vs. Roof thickness
PostPosted: Wed Oct 19, 2016 2:35 pm
by Pwfyrcat1
If the walls of my camper are 2 inches thick, does the roof also need to be the same thickness? Or can I go with a 1 inch roof? Or should I?
I know lots of questions today :roll:
Re: Wall thickness vs. Roof thickness
PostPosted: Wed Oct 19, 2016 3:12 pm
by MtnDon
I like insulation, so I'd go with same or thicker.
PostPosted: Wed Oct 19, 2016 4:16 pm
by Tomterrific
How wide? How high? I see some small campers being shrunk inside by thick materials, poor design. If you need the extra insulation for very cold weather camping then I think heavy, thick insulation might be needed. Our camper has only 3/4" Styrofoam in the roof and none on the walls. We have camped on cold nights (32°) with only an electric blanket. We still had the ceiling vent open which probably made the ceiling insulation moot. If you are thinking of sun and hot weather, then you should think bright white paint and lots of ventilation.
T
PostPosted: Wed Oct 19, 2016 5:01 pm
by tony.latham
Is this a foamy or a sandwiched-wall build?
PostPosted: Wed Oct 19, 2016 6:41 pm
by Pwfyrcat1
tony.latham wrote:Is this a foamy or a sandwiched-wall build?
foamee :D
PostPosted: Wed Oct 19, 2016 6:56 pm
by tony.latham
foamee :D
And thus it's in the Foamies section. Missed that.
PostPosted: Thu Oct 20, 2016 12:40 am
by Andrew Herrick
For a space as small as a camper, insulation isn't the issue here. You'll stay fairly toasty (or cool) whether you choose 1-inch or 2-inch foam. But if my memory serves me ... isn't 2-inch foam just a few bucks cheaper than 1-inch foam? And here's the thing: It can support 8x more weight when bending. 8x! So unless you're pressed for headroom, go with the 2-inch or 1.5-inch foam. It might cost a little more, but you'll never worry about a hail storm :)
PostPosted: Thu Oct 20, 2016 6:09 am
by GPW
We're with Andrew .... hail storms of falling limbs ... We’ve already had a limb go through the roof and into the cab , and that was through a “membrane" ( very thin) 3’32” plywood , and 2” of EPS (beaded) foam , and ceiling paper ... ( commercial RV)
