Page 1 of 1
Harbor Freight 130W hot knife ?
PostPosted: Wed Dec 21, 2016 5:35 pm
by rustytoolss
Has anyone used the 130 watt harbor freight Hot Knife , for cutting 2" XPS ? What were your views of the tool ? :thumbsup: :thumbdown: :thinking:
Re: Harbor Freight 130W hot knife ?
PostPosted: Wed Dec 21, 2016 7:05 pm
by GuitarPhotog
I fear it might be way more power than you need. I cut mine with a 15W hot wire, made from a wall wart and a piece of nichrome wire. For doing notches and kerfs, you can use heavier nichrome wire and an old 35W soldering gun.
My $0.02 worth
<Chas>
:beer:
PostPosted: Wed Dec 21, 2016 7:18 pm
by ghcoe
I have heard they do not last too long, but they may be improved by now. The knife does have a temperature control dial so you can dial it to the temp you want. I have not used one, but have looked at them a few times.
PostPosted: Wed Dec 21, 2016 9:46 pm
by pchast
I made a mess with one trying it out....
Wrong technique? I don't know.
PostPosted: Fri Dec 23, 2016 9:30 pm
by greygoos
It takes some practice. The blade is very thick and the foam seems to melt on the blade. I cut some 2 inch for the floor and put it on the shelf. I would only use it outdoors.
PostPosted: Sat Dec 24, 2016 5:33 pm
by rustytoolss
Thank for the information, I just built my own hot wire cutter. It worked better that I expected. About the only problem I had, was the circuit breaker kept cycling. I have a transformer from a HO Trains set from about 20 years ago. Going to try that.
PostPosted: Sat Dec 24, 2016 7:33 pm
by GuitarPhotog
rustytoolss wrote:Thank for the information, I just built my own hot wire cutter. It worked better that I expected. About the only problem I had, was the circuit breaker kept cycling. I have a transformer from a HO Trains set from about 20 years ago. Going to try that.
A model train transformer is about ideal for making hot wire cutters. Variable output, high current capability, and often internal fuses/circuit breakers.
I got real nichrome wire from Amazon. I used AWG16 or 18 for my hot wire "jig saw." For cutting straight pieces out of sheets. And I used 12-14 ga for my "profile cutter" to cut the notches for my angle iron frame and roof spars. I put that in a soldering gun I got at Goodwill for $2.
<Chas>
:beer:
PostPosted: Sat Dec 24, 2016 9:36 pm
by rustytoolss
At this point I'm using 1/16" wire for torch Oxygen/Acc welding. As it was the only wire I had small enough to test with. And I will need to use it with the transformer / for now anyway. Do you have any pictures of you hot wire cutting tools ? they may give me some ideas. Merry Christmas :)
PostPosted: Sat Dec 24, 2016 9:43 pm
by GuitarPhotog
rustytoolss wrote:At this point I'm using 1/16" wire for torch Oxygen/Acc welding. As it was the only wire I had small enough to test with. And I will need to use it with the transformer / for now anyway. Do you have any pictures of you hot wire cutting tools ? they may give me some ideas. Merry Christmas :)
They were all one-use tools make just to cut the insulation panels for my trailer. Sorry.
Try the train transformer on low-throttle first, and pay attention if it starts getting warm. It's easy to burn up power supplies when drawing high current such as a hot wire requires. There's a site that provides power and temperature calculators, but if you are using just what you have wire, they'll do you no good.
My first hot-wire cutter ran off a string of 1.5V dry cells. The nichrome wire came from an old (I mean really old) toaster.
<Chas>
:beer:
