Concealing wires for exterior & interior lights?
Postby rustytoolss » Wed Mar 15, 2017 11:01 am
My mind is in full on build mode. How have you guys concealed wires (in the foam) for exterior body lights, when you have a canvas/PMF covering inside and outside ?? Also mounting the lights ? I have some ideas. But would like to see what others have done. Thanks
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Concealing wires for exterior & interior lights?
Postby bonnie » Wed Mar 15, 2017 11:05 am
Outside I will -- when it finally stays warm -- be using flashing and pvc boards. Pictures will be forthcoming.
Remember, the turtle won. :)
bonnie
Images: 107
Postby bonnie » Wed Mar 15, 2017 11:06 am
Inside I am going to use cable covers for the single run of 12 volt wiring
bonnie
Images: 107
Postby KennethW » Wed Mar 15, 2017 11:15 am
Why conceal? it will make it a lot harder to add or change stuff later. Just keep it neat. Maybe paint the wire the same color as the inside and run the main feeds along the roof-wall corner.
You could easily cover the corner with plastic corner molding.
Just my thoughts
KennethW
Images: 82
Postby John61CT » Wed Mar 15, 2017 12:03 pm
all of which fall within "concealing"
Best is to leave channels or bury conduit, run more/bigger wires than you think you need, plus strong fishing wire for later pulling.
John61CT
Postby GPW » Wed Mar 15, 2017 4:57 pm
We just route ours through the holes in the ribs ... easy , easily changed if needed ...
Postby ghcoe » Wed Mar 15, 2017 6:26 pm
I used a hot wire to cut channels and then glued the cut out portion back into the channel. I have had to rethread a wire and it worked just fine. http://tnttt.com/viewtopic.php?f=55&t=54099&start=345
George.
ghcoe
Postby KCStudly » Thu Mar 16, 2017 2:45 pm
I have used several methods. Primarily in the cabin I have run wire mount track (intended for training computer cords and whatnot) along the base boards where it will more or less be hidden by the mattress. Drilled thru the back of this out for trailer running lights.
For light switch locations, dome lights (which I mounted on the side walls high up) and the roof fan wires I routed channels in the foam from the base board up prior to laminating my inner wall skins on, then just fished the wires thru. Used a similar technique in the bulkhead to bring wires from the street side baseboard up to the hatch hinge to jumper to the hatch for galley light, lic plate and taillights, as well as feeding the linear actuators.
I decided to add another power circuit to a potential future entertainment center at the top center of the bulkhead, but by this time in my build it would have been really hard to add anymore hidden wires thru the bulkhead, so put a shallow square box in the roof/ceiling, drilled each roof spar and left a channel gap in the first 3/4 inch thk layer of roof foam, which subsequently got bridged over by the second layer of roof foam.
Later in my build I decided that I wanted high clearance lights on the sides, so before skinning the outsides of the side walls I routed channels from the lower running/side marker lights, laid the wires in, cut narrow strips of foam slightly over sized and glued them in over the wires.
All of this (and a whole lot more!) is documented in my build thread.
