Page 1 of 1
Filling dings and gaps in foam?
PostPosted: Mon May 15, 2017 8:27 pm
by steepski
I picked up some cheap xps foam from a local construction site. It's in great condition for the most part, but has a few small gouges and dents. Any ideas on what would be the best to fill them in with? Standard spackle or joint compound?
Thanks!
Re: Filling dings and gaps in foam?
PostPosted: Tue May 16, 2017 6:06 am
by John61CT
Great Stuff applied sparingly, level off with a wide putty knife, then when set a Surform plane
PostPosted: Tue May 16, 2017 6:12 am
by GPW
You could try spritzing it with some water, covering that with a cloth towel and Ironing it on a mid heat setting … :thinking: The steam re-expands the foam …
Some people pour boiling water over it , from the kettle … Try that first ..
