TERRA6, Van cab and chassis 7*14, 4" Polystyrene
So I've gone ahead and took the plunge
Here's the story and background.
After spending most of 2018 researching, thinking, planning, hoping, worrying etc... I've decided to build out a foamie on a van cab and chassis that I bought. See my other threads for pics on rig and proposed style.
Having built things before, a small 6*10 steel stud and wall camper on a harbor freight 4*8, sort of kind of have some experience. And built other things. I use the term build very loosely for my craftsmanship skills. I only have portable battery powered tools and no carpentry or cabinetry 101 training. None.
But where there's a will there's a way I say.
Decided that a full foamie, minimal framing and PMF was light, cheap and durable enough. Could I pull it off was the question having had zero experience with them.
So the idea of unconventional and light weight appeals to me as does low cost and light weight. Ideally.
The low cost is always debatable at the start of a project and not necessarily what you end up with.
As all projects end up over budget.
This was my main concern, the cost factor. If one can build it for much less than conventional materials or comparable vehicles, can justify the weak points of structural and outer skin limitations of foam and PMF builds. But if it costs you the same, you've spent all that time and money on something that is inferior. Worthwhile is the question as well as value for time and money spent.
Have no concerns on the feasibility and benefits, only cost, overall value to a comparable box truck. I looked at ambulance boxes but they were heavy, not spacious and lacked headroom for the ones that I saw. Not ideal but could be had in my area for $1500.
Found a fiberglass box made exactly for my chassis for which they wanted$1500 also. It was a little rough and not negotiable on price. So I sat on that as a fallback. The fiberglass was thin, not super strong, but enough to do the job with heavy wood flooring. It was as light as could be had for a commercial unit. It also had the huge garage door at the back which I would have to gut and build.
So I was constantly looking on craigslist for materials for bargains and deals. Was flip flopping between a conventional wood and ply build, aluminum foam core or PMF foam build with minimal framing for Max light weight. Even considered drywall metal studs which I had used before which were light and strong but costly compared to wood studs. On a small project the extra cost wasn't significant but on a bigger build it added up quickly. Wouldn't hesitate if I had the budget, maybe on another build.
So on Craiglist, the stars aligned and three things came available at the same time at low cost.
1. The foam. Polyiso 2" in my area is going for $40 a sheet, much more than elsewhere. Big cost, if I could reduce this, would be great and make the project worthwhile. If not, should just buy the box and bolt it on.
For a build on something for which I was inexperienced, didn't make sense to take the risk for something that I wasnt sure I could build strong enough on a vehicle. Unless I could do it really cheaply than the failure could be easily written off. Spend serious money and have it fail or need to be redone, well, might as well just light money on fire. The structural strength and requirements for the size I wanted to build 6-7*12-14', couldn't find a pre-existing model to copy from and was a proven design.
I was boldly going where no man has gone before.
So I managed to locate a seller who had 4*8 sheets of used 4" Polystyrene for $14. That was worth learning, taking a chance and not losing too much in the worst case scenario. Fear and the unknown play a huge part when we make decisions. Understandably.
2. Glue. Everyone builds with TB2 but the water resistance only aspect was a concern, even if in the Southwest. To me TB3 is the way to go but it is much more expensive. And with a much larger surface area planned than a 4*8 teardrop, was going to take a lot more. 3x more I figured, hundreds of dollars worth. If I could get it cheaper than $28/ gallon. Hmmmm.
Found I could. HD lists a 2 * 1gallon pack for $42 online. That's $21/ gallon or just a bit more than the $18/ gallon of TB2. It's a go, sort of. HD doesn't stock TB3 in my area or state. But some Lowe's did. Thank you price matching and overworked managers who approved the price reduction. 10 gallons btw.
Two out of three, not bad so far.
3. Now paint. Mistints are okay at $9/ gallon but how many gallons did I need for approx 400ft2? Had no clue but if I could go cheaper would be great.
Once again, on Craig's, found a large paint contractor who was selling is leftovers for $2/ gallon. Great. Picked up everything that he had. 27 gallons. I was making sure that I had enough paint and wouldn't run out. At $2/ gallon, bought it all, cost me $50. I had paint and was good to go.
4. Oh, there was another major cost, glue. Which type and how much. This was the critical component for success, structural ridgity, and making it all possible. Many where using gorilla glue but at $8 a small tube and a large project, didn't seem economical and would quickly kill a budget. For this size of project, going to need allot of glue and $8 is expensive for a little tube. So I wondered if PLP 3 which came in the construction size tubes which is 3x larger but at the same $8 cost would be strong enough. That was the cheapest potentially strong enough glue that would do the job that I could source locally. Did a test with a piece of wood buttered with glue to a block of 4" Polystyrene and waited a day for it too dry. It wasn't coming off without disintegrating from the foam. I was sold and everything was go at that point.
So I said to myself, I could pull this off as cheaply as possible with all of the main costs, I could do this on a budget and reasonable cost. Why not?
Fear, the unknown and no experience with these materials. Regardless of what anyone says on here, these builds and materials are not as durable as conventional. That's a serious downside but if it's a small fraction of the cost, then worthwhile. But they are good enough for the cost. And don't consider the cost or time of your labor.
So at this point, I said f*kit and made an executive decision, ordered the foam from the seller delivered.
There was no going back at this point when he arrived with the foam.
To be continued.
To be continued.
