Question on fill compounds over foam
Postby RJ Howell » Sat Aug 03, 2019 7:52 am
I've read of folks using spackle to fill dents or small holes. Curious if anyone has used Dura-bond compound with sucess?
My intent is to edge the with a drywall bullnose bead like this.
https://www.homedepot.com/p/Phillips-Manufacturing-Company-8-ft-x-3-4-in-Vinyl-Bullnose-Corner-Beads-35-Pack-BN3VYL/202035413
I did read a thread of another using some like this, but from the pictures I don't think it was coated..
I would need to coat the bead so the perforations don't show through the skin.
RJ Howell
Images: 36
Re: Question on fill compounds over foam
Postby ghcoe » Sun Aug 04, 2019 10:03 am
The Big Pink thread used something similar. He might pipe in on this. I do believe he glued it on with Gripper, but not sure how he filled the holes.
I have had great results using the Fast and Final spackle to do the filling of voids and dimples in my builds.
George.
ghcoe
Postby John61CT » Sun Aug 04, 2019 10:28 am
I would use the same primer/adhesive as below, mixed with a tested-compatible filler
powdered talc
cabosil fumed silica
glass bubbles aka microspheres
John61CT
Postby RJ Howell » Sun Aug 04, 2019 11:12 am
ghcoe wrote:The Big Pink thread used something similar. He might pipe in on this. I do believe he glued it on with Gripper, but not sure how he filled the holes.
Believe that's where I saw the bullnose being used. If so, I sent a PM to learn if he did. I did read he glued on with GC. By the picture I saw.. well, I'm not sure he coated to fill the perforations in the nosing.
Thank You!
RJ Howell
Images: 36
Postby RJ Howell » Sun Aug 04, 2019 11:22 am
I came in to check my posts and read this. I just finished sampling out a few areas with Dura-bond.
I ran out before I got to by 90 corner sample. I want to sample this against what I did with the GC. Thought is simple: Use mesh tape (fiberglass) with Dura-bond over.
So far the Dura-bond is sticking without bubbling. Have a fairly thick coat and some skim coating done. It's Dura-bond 90, so it has some open time.
What the hey, seems no one else tried this so here comes the experiment.
RJ Howell
Images: 36
Postby tac422 » Sat Aug 10, 2019 8:16 pm
I just saw this ..
I did not fill the perforations, or feather the edges of the molding. The perforations don't show through the canvas.
110836
tac422
Postby zzzizxz » Wed Aug 14, 2019 8:24 pm
I did fill in the holes and smooth the edges of the corner bead on my build.
I used Menards version of vinyl spackling.
https://www.menards.com/main/building-materials/drywall/spackling/red-devil-reg-onetime-reg-white-lightweight-spackling-1-pt/0548sq/p-1444452036469-c-8201.htm?tid=-5929727470169446924&ipos=4
I wanted the walls and seams to be as smooth as practical on my build, so I primed the foam, then put on the spackle, then primed over that again. Then, I wrapped the roof canvas over the edge of the walls, and when that was dry, spackled the edges of the canvas smooth. After priming that, I put the wall canvas on, but cut that right at the corner for a neat finish.
zzzizxz
Images: 142
