What size spline for 1 inch foam.
Postby UPRider » Mon Feb 17, 2020 2:16 pm
[album][/album]Hello All
I'm in the planning and design stage at this moment. My question is this. What size spline for an side to side joint ? ie 4 x8 is now 5 x 8. This for a 1 inch Foamie. I have several sheets of 1/4 inch underlayment. Just wondering if this will work.
TYIA
Red
UPRider
Re: What size spline for 1 inch foam.
Postby Pmullen503 » Mon Feb 17, 2020 6:04 pm
1/4" is overkill, 1/8" ply would be more than enough. That 1/4" may be more like 0.20". Too loose a slot means the spline won't do a very good job of lining up the edges. I'm assuming you would use a wing cutter on router to make the slot. Two passes with a thinner cutter would let you get a better fit.
Pmullen503
Images: 67
Postby GPW » Tue Feb 18, 2020 6:57 am
Hi, Red , You have a sketch or something we can “consider” … We're kinda’ “picture people “ around here …. Better to Visualize what you’re doing … :thumbsup:
Postby UPRider » Tue Feb 18, 2020 7:33 pm
Hey Guys
Pmullen. Yeah I kinda figured it was overkill but wasn't sure. Thanks.
GPW. Here ya go.
Don't let the sketch fool you. The wheels are not located on the rear and the door may be moved to the front. All depends on where the axle lands.
UPRider
Postby UPRider » Tue Feb 18, 2020 8:40 pm
Damn file size too big. Sorry GPW.
Anyway. I wa 60 inch walls instead of 48.
UPRider
Postby GPW » Thu Feb 20, 2020 6:38 am
UPR, That’s a Good height !!! :thumbsup:
Try putting your sketch file into a Photo program where you can easily adjust the size … :thinking:
