Question... is the foam with PMF firm enough to act as a sealing point with the hatch frame? There will be slight pressure on the foam. Just enough to depress a couple rubber weatherstripping strips.
If not, if I epoxied that area to make the mating surface more firm would that work? Is there a need to add aluminum flat stock here?
I hope these photos help...
The pink foam with 1 1/2 sharpie mark on it represents the hatch profile. There is a 1/2" plywood galley wall that provides a half inch flange to block water penetration. The hatch frame member will mate with the flange with a rubber seal inside. That will be the last blocking of water penetration and will be "tight". The other seals will be on the flat surface of the wall profile and provide some water seal, but will not be under much pressure. That is the area I am concerned about being firm enough to support the slightly depressed seals.
Thanks, Tim
