solar panels on foamie roof?
Hi,
I'm new here, currently working on a 10.5' x 5.5' x 5' foamie squaredrop.
The floor and drop floor are done. I'm about to get to the foam construction. Due to the size of the design I'm edge gluing foam panels and plan on using a channel cut along the edge joints to form tongue and groove that will lap over the edges of both foam pieces, add some additional support and give me something to screw into.
As for the solar panels they are roughly 64"x34" and 42lbs each. So I think I'm going to run a plywood beam along each outside edge of the camper inset on a channel cut on the outer edge of the roof piece. Again just for something hard to screw to and for the railing to sit on.
The walls are just 2" foam/pmf. No wood for vertical supports in the plan, just the vertical walls at the front and back.
I guess I do have some concerns about how the points where the roof will be penetrated will hold up to water and potential wear at the points where the roof rack contacts the roof.
Any pointers?
Any pointers?
