Re: My first Foamie build-slide in truck camper for 1979 Toy
Posted: Wed Aug 03, 2022 8:11 pm
Nice work! I wonder how did you build that fiberglass flange for the back door seal...
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
OP827 wrote:Nice work! I wonder how did you build that fiberglass flange for the back door seal...
jakejakejake wrote:OP827 wrote:Nice work! I wonder how did you build that fiberglass flange for the back door seal...
Thanks. The door flange is layed up on top of foam with the desired profile, and once cured the foam is removed from behind it. When I glass the outside I will overlap the two sides at the back of the flange. I have some plans for the door that will cover the same techniques. I will be sure and get some video of it.
jakejakejake wrote:I also built with fiberglass and went quite extreme with only one 6oz layer on outside
ghcoe wrote:I just watched your video. Looks great!
I do think though, you will find the rafter ends telegraphing through your fiberglass layup. Foam and wood expand at different rates and under certain thermal conditions you will find the wood trying to poke out of the foam. This will lead to delamination of the fiberglass and foam at those locations.
jakejakejake wrote:Awesome roof raise mechanism Oleg!
I tend to be quite rough on things, a real "break the holes out of a bowling ball type". Im a welder/Fabricator and mostly work with mild steel, I imagine I could cut my layer count by half, but not really knowing the "feel" of this stuff like I do steel Im just shooting for a happy medium of strength to weight. I guess only time will tell.
twisted lines wrote:Nice!
I would like to see a material list for your epoxy, clothe filler Ect. Don't tell Tony
