If you were to build it all over again ...
If you were to build it all over again, what's your main reason for rebuilding?
I really wanted better quality
29
14%
I really wanted it longer
16
8%
I really wanted it taller
9
4%
I really wanted it wider
43
21%
I really wanted it lighter
35
17%
I really wanted a woodie
6
3%
I really wanted a vintage looking aluminum one
7
3%
I really wanted a more modern looking one
1
0%
I really just want to purchase a factory model
6
3%
Other, I'll add my note below!
53
26%
Total votes : 205
Re: If you were to build it all over again ...
Postby Dahlia47 » Fri Sep 06, 2019 9:10 pm
I didn't build ours. It was built by someone else. What I would do differently if I had built it is put the door to the rear and move the bed towards the neck. Its a pain to pull the bed frome towards the neck and rolling the futon towards the neck. If these 2 things were switched, It would make towing and stability much easier.
Dahlia47
Return to User Polls
