cut all at once or cut as needed
How did you cut you plywood pc's
1. it looked like a puzzle cut as much as I could from 1 sheet
3
33%
2. Got some ply and cut it as I needed it.
6
67%
did mostly 1. but some of 2.
0
No votes
Total votes : 9
Postby Ron Dickey » Sun Jul 27, 2008 9:42 pm
when you designed your trailer or modified the trailer plans that you got.
Did you do the figure what would fit on a pc of plywood then cut it all at once or did you cut it as you needed it.
I cut as needed now I am planning to try and fit most of the pc's needed from one sheet as prices rize.
173882......173887
Ron Dickey
Images: 787
Postby SuperTroll » Mon Jul 28, 2008 1:11 pm
I cut the larger pieces first, then took the scraps and stacked them off to the side.....when I needed the smaller pieces, I marked and cut them from the scraps...worked out well....
Since what I built was done from photos and a few written specifications, layout was a guess, there were plans available, but typical to the Male, I said in my heart...."PLANS?!...I don' need no steeenking PLANS!"...
working out the specifics during the build was part and parcel to the project...exercise both the hands AND the mind....
so the answer IS: A little of both.....
(Wadda I win, huh?, huh?...there's a prize right....oh boy, oh boy..wadded I win?)
Keep thinking outside the box and all manner of ideas will become reality......
http://home-and-garden.webshots.com/alb ... Ul?start=0
SuperTroll
Postby bobhenry » Mon Jul 28, 2008 1:25 pm
SuperTroll wrote:I cut the larger pieces first, then took the scraps and stacked them off to the side.....when I needed the smaller pieces, I marked and cut them from the scraps...worked out well....
I couldn't have said it better. However, since I ran my 4x8 sheets vertical I will add that I was careful that seams fell on reinforced areas like the galley wall and at the door edge. I may have wasted a little more that way but it made sense to me to have the seams reinforced.
Postby Dean_A » Mon Jul 28, 2008 1:48 pm
If I had tried to cut it all at once, I would have wasted a LOT of plywood. My "plan" changed on a weekly basis. :lol:
Dean_A
Images: 55
Postby planovet » Mon Jul 28, 2008 3:08 pm
I'm with Dean. I bought AND cut as I needed it...
ImageMark (& Cindi)
planovet
The Cat Man
Postby starleen2 » Mon Jul 28, 2008 6:50 pm
Cut as needed! not too good at planning ahead. However I did have to take some back - bought too much - BOTH TIMES
starleen2
5th Teardrop Club
Postby SuperTroll » Tue Jul 29, 2008 9:41 am
No taking any of my ply back, because before I did ANYthing, I used a pan and roller and coated every piece of ply with sealer.....doesn't matter if you use waterproofing or paint sealer, by sealing the whole flat sheet FIRST, the only thing you need to do afterwards is seal the edges...same with specification lumber...unless you intend to stain it, SEAL it.
Then, when I began the layout process the pencil stood out because of the white sealer I had used...the red chalkline also stood out well.
SuperTroll
Postby S. Heisley » Tue Jul 29, 2008 5:55 pm
I coated all my deck plywood with sealer (CPES) before I cut it. Then, I had a little of the sealer left over so I coated 'em again. After it was dry, I cut it...or tried to. Ruined two brand new saw blades and had to recharge the batteries three times but I finally got through it. I finished up the last 3 inches of the last cut with a hacksaw and a lot of patience. If CPES had been around during WWII, they coulda made tanks outa plywood triple coated with that stuff! From now on, I'll cut only what I need when I need it; and fit and drill it first before sealing! ...Talk about learning the hard way!
Postby mikeschn » Tue Jul 29, 2008 6:55 pm
I think you won a round tuit... Just print this out and cut it out! :)
P.S. I cut as I go also...
Return to User Polls
