As you build your TTT what expence do you go to?
What expence will you go to in Building your TTT
The Sky is the Limit
6
13%
Penny Pincher
8
17%
I expect to spend the usual amount around $3000
18
38%
cheep as I can go and add as I can afford.
11
23%
My manufactured one has got what I want
1
2%
I will build a new TTT later with what I really need
1
2%
TTT?? I have no TTT... but I can dream !!!!
2
4%
Total votes : 47
Postby doug hodder » Tue Nov 22, 2005 11:13 pm
I've built a number of larger projects and the reason I built a 2nd boat is that I cut corners on the first one and wanted it different....I would say that unless you are planning a 2nd tear from the get go....build it the way you really want it....you're going to be a lot happier with it than having to live with yourself and a project knowing what you could have done and didn't...When it is all said and done, the dollars now and the effort are a lot less expensive than doing it all over again....Just my experience...PS...I've got a 15' Mohogany boat that I'll sell...Doug
Postby cracker39 » Wed Nov 23, 2005 2:35 am
ALAN GEDDES wrote:I keep wondring where that $3K figure comes from. I have built three from $300 to $1200. Are people figuring in camping gear and tools too?
That's interesting. How do you build one for $300 when a chassis costs nearly that much if you buy one new. My 5x9 chassis will cost close to $500 to build, counting the steel, 13" tires/wheels, axle, coupler, jack, etc. And that's with free welding. My plywood alone will cost around $300. Check out my thread http://www.tnttt.com/viewtopic.php?t=6004 on costs of building.
Dale
cracker39
Images: 233
Return to User Polls
