Suspension Type?
Suspension Type?
I used Leaf Springs and would use them again.
22
49%
I used Leaf Springs but would use a Torsion Axle the next time.
3
7%
I used a Torsion Axle and would use it again.
19
42%
I used a Torsion Axle but would use Leaf Springs the next time.
1
2%
Total votes : 45
Suspension Type?
Postby Gerdo » Sun Oct 29, 2006 10:24 am
Are you happy with the suspension type that you have on your Teardrop?
Gerdo
Images: 156
Postby Ron Dickey » Sun Oct 29, 2006 1:50 pm
I have not pulled mine yet it is shocks and leaf it is an old boat trailer.
121377......134179
Ron Dickey
Images: 711
Postby ALAN GEDDES » Sat Nov 04, 2006 5:25 pm
I use leaf springs because I can get repairs or parts almost anywhere.
Alan
ALAN GEDDES
Images: 34
Postby Gaston » Fri Nov 17, 2006 10:47 pm
I used a torsion axle so I wouldn't have to get parts anywhere!
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby Gage » Fri Nov 17, 2006 10:55 pm
Gaston wrote:I used a torsion axle so I wouldn't have to get parts anywhere!
Good answer. :thumbsup:
I have leaf springs. They came on the trailer I used as a donner.
:lol:
Image Image Image
Gage
Images: 28
Postby PaulC » Sat Nov 18, 2006 12:45 am
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Steve_Cox » Sat Nov 18, 2006 1:12 am
For the most part the only trailers I've seen along side the road were POS trailers with leaf springs, flat tires or wheel bearings that were not maintained. If I was to build an off road trailer it would probably have a 3500# axle, 2000# leaf springs and shocks. I like my independent suspension Flexiride axle, the only plans I have to take it off the pavement is when I back into a campsite.
Steve_Cox
Images: 196
Postby Ma3tt » Sat Nov 18, 2006 2:08 am
My original torsion axle went out after 58 years, luckily in the driveway, the Tear did look nice lowered 4". So I guess if your building a tear with a torsion axle plan on replacing it in 57 years!
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
Postby doug hodder » Sat Nov 18, 2006 8:21 am
Sort of a Ford VS Chevy thing....I've done 3 with springs, because I can walk in and buy the axle right now, but have built lots of smaller utility trailers with springs and torsion axles...If you want a heavier duty trailer, you can always stick in a new pair of heavier springs, provided you have the frame for it, which is cheaper than a whole axle assembly, but this assumes you're talking about a custom build, not a frame out of a box. I miscalculated the unbuilt weight on my first one and hammered it out on the highway...way too fast on rough highway...a 12$ fix in Minden got me home and I slipped in a new pair of stronger springs. .....Doug
Postby Denny Unfried » Sat Nov 18, 2006 10:04 am
Leaf's on mine for most of the reasons mentioned above.
I think many leaf failures are caused by builders tightening the shackle bolts to tight to where the leaf can't swivel on the bolts which will certainly break a leaf eventually. Also bolts should be inspected and lubed periodically to prevent wear. Should be done much more often if you're an off road-er.
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby dwgriff1 » Sat Nov 18, 2006 10:56 pm
Agree with Doug. Both can work well.
I own a collection of trailers (travel, flat bed tandem, box, tear) half with springs and half with torsion. No problems with any of them.
My tear is a torsion axle. My next tear (if there is one) might have either, depending on other factors.
dave
dwgriff1
Postby JunkMan » Sun Nov 19, 2006 9:43 am
I've got trailers with both. I prefer the torsion axel on the tear because it is cleaner, and I can get the ride height where I want it (low) easier.
I've broken several springs over the years, and worn out many bushings and shackles. These were all on large tandem axel flatbed trailers that had a LOT of miles on them, and were usually loaded VERY heavy.
I have a little (1000 pound capacity) utility trailer that is 30 years old and still has the original springs, and has never given me any trouble. I very rarley load it any where near capacity (usually just haul the garden tractor with it), but have had it maxed out a few times.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Return to User Polls
