Page 1 of 1
What is the best battery for teardrops
PostPosted: Sun Sep 30, 2007 9:08 am
by kartvines
Madjack brought up a good question, I do believe that most on this board are using the Optima battery, but he has heard that they do not have a good life, he suggested maybe the Trojan or Lifeline may be a better battery what is your opinion?
I prefer to buy the correct battery the first time out.
PostPosted: Sun Sep 30, 2007 9:19 am
by madjack
..another consideration is cost...I really like the AGM type batteries but they are spendy...you can buy a couple or 3 wet cell batteries for what some of the AGM's cost...of course, you also have to deal with the problems from out gassing by placing them in a non-spark enviorment and providing adequate ventilation for them...in my new build, I am using a pair of these http://www.batterymart.com/p-6v-33ah-se ... ttery.html
mainly due to physical size... my power requirements are fairly low and most of my camping is at parks with shore power available...I will also use a Deltrans 5a Battery Tender over the top of them, to keep them up and provide 12vdc power while hooked to 120vac... http://batterymart.com/p-battery-tender ... arger.html
madjack 8)
PostPosted: Sun Sep 30, 2007 10:51 am
by Arne
I like the idea of those batteries. My 6 pack weighs about 60 pounds. I do need a bigger charger. the .75 amp b/t takes to long to recharge when I use the generator... will look into a 1.5 amp floater when the time comes.
Oh, did you go 2 - 6 v in series for size, or can you get more amps/lb. that way?
