question for on second build or 3rd or 4 th etc.
You guys are amaxing working on mine is taking me 4 years but I started with little to know experiance (or so I thought) and you guys are building new ones as backups, hobbies, or for the sure hell of it.
There will be know click on the dot here because it would go on for an eternaty adding things to each line, you would sit in front of your monitor for days until you found the right dot to hit.
so......
HERE IS THE ONLY QUESTION ....(need the music to one of those we will come back after the commercial to see your answer thiings) you do not have to answer it now you can go out and look at your trailers
think about it and come back in a week with the answer.
What did you change over the older one or ones and did it work?
Manufacurers I know you are reading this thead so what did you change and why and did it sell better or did you get good feed back because of it??
The Poll Master
so......
The Poll Master
