Page 1 of 2
Mattresses
Posted:
Tue Mar 27, 2012 6:15 pm
by Rlowell
What type of mattress are you using and why? How tall is it? How long have you used it?
Re: Mattresses
Posted:
Tue Mar 27, 2012 9:07 pm
by PKCSPT
Twin mattress for a sofa sleeper because it was new and free, tear is only 4 feet wide so it works great.
Re: Mattresses
Posted:
Wed Mar 28, 2012 5:42 am
by bobhenry
BEST ! Simmons queen pillow top in Chubby ( I had to build the trailer around it )
GOOD! The 4x8 is a cut down 4-5" Memory foam
Just O.K.! 4" 2 piece foam in "the barn" for the couch bed combo.
I use a thin futon topper when in bed mode and it sleeps much better !
Re: Mattresses
Posted:
Wed Mar 28, 2012 11:58 am
by deceiver
We've got one of those $299 walmart spa foam mattresses, 8" it has 3.5" of miracle foam over foam rubber on the rest of the 8". Sleeps so well it will be our next in house mattress... oh, it bends to insert into the teardrop through the door.
Re: Mattresses
Posted:
Wed Mar 28, 2012 2:09 pm
by absolutsnwbrdr
I have the 4" Spa Sensations from Walmart. Pretty good mattress for $120. I only weigh 150lbs though. If I were heavier I might be more inclined to buy a thicker mattress. This one just suits me very well.
Re: Mattresses
Posted:
Wed Mar 28, 2012 4:00 pm
by Shadow Catcher
I bought ours from
http://www.mattressbymail.com Queen 5" Lux R foam, medium firm. The 4" would have been enough. I did not want memory foam as some of the locations we will likely be are COLD and reportedly it becomes VERY stiff. And it is very hard to beat the price!
Re: Mattresses
Posted:
Wed Mar 28, 2012 4:40 pm
by GuitarPhotog
I just had the local foam shop custom cut me a piece of 5" medium density open-cell foam to fit the trailer. The biggest hassle is getting it in or out of the trailer. Oh, and I bought it when gasoline was ~$5.00 a gallon, so I paid through the nose for it
<Chas>
Re: Mattresses
Posted:
Wed Mar 28, 2012 4:57 pm
by halfdome, Danny
I use 2 pads for ease of putting it in the teardrop, rotation for even wear and ease when putting sheets on.
They are 4" of 2038 medium firm foam and 1" of memory foam covered in a cotton/poly cover.
The zipper is around side edges of back/bottom.
In other words a zipper on 3 edges of the thickness at the bottom of the cushion.
No zipper on one long edge.
http://www.foamorder.com
Danny
Re: Mattresses
Posted:
Fri Mar 30, 2012 12:44 pm
by canonsue
I just purchased a latex topper as my foam matress that came with my little guy I very hard. Even though latex costs more it is much more comfortable in cold and hot temperature. I have not sleeped on it yet k I will give a report after my next camping trip.
Sue
Re: Mattresses
Posted:
Tue Apr 17, 2012 10:01 pm
by Rlowell
Thank you everyone. That is a lot of good information and some good links. I will settle on a choice soon and let you know
my results after I try it out.
Rod
Re: Mattresses
Posted:
Wed Apr 18, 2012 11:39 pm
by Ron Dickey
We went to a upholstery supply store, our trailer is a little smaller then a full. I used a razor blade to cut it. We got a firm. we have since added a egg crate to it to make it a little thicker. I am thinking of adding a 2nd one or make a thin boxspring.
Put bed sheets on it and several layers of blankets depending on the temp. no heater but the trailer is well insulated.
Re: Mattresses
Posted:
Thu Apr 19, 2012 1:27 am
by asianflava
I use a 6in foam mattress from Wal-Mart. It has 4in foam on one side and 2in memory foam on the other. You can flip it over if you don't/do want the memory foam. Originally designed my tear for a 4in mattress but this works fine, a little tight in the foot box, but the extra height makes it easier to sit on the door sill.
Re: Mattresses
Posted:
Thu Apr 19, 2012 3:07 am
by steveyos
I have twin 4" memory foam topper because it is just me in a 4' wide. I also got two new pillows at Target and it's a great place to sleep.
Re: Mattresses
Posted:
Thu Apr 19, 2012 9:20 am
by dano
I just ordered a Qeen size Futon mattress. 60x80"x8". Hope it works. Will let ya know when it gets here.
Re: Mattresses
Posted:
Fri Apr 20, 2012 7:33 pm
by LDK
Ron Dickey wrote:We went to a upholstery supply store, our trailer is a little smaller then a full. I used a razor blade to cut it. We got a firm. we have since added a egg crate to it to make it a little thicker. I am thinking of adding a 2nd one or make a thin boxspring.
Thats what I did. I went to a upholstery supply store,(DLT) and bought a 3" extra firm piece of foam cut to size and I also used a
eggshell mattress topper too. It worked out real good.
