30 day question perplexed
Going to Pamplingrove .... which way should I do it.
Poll ended at Mon Jun 12, 2006 2:01 pm
Retrun all trailer parts .. put back on old bearings get 4 prong tires
1
8%
finish the main body build a holder for the truck put in Bed.
0
No votes
Get a new spindle put on the trailer or axle ($amount unknown)
0
No votes
If you are not done Drive the Prius up and sleep in a Tent
4
31%
#*^@?? Dam .... I don't care just get up there .. stop sibeling
2
15%
Do what you got to do and get up there .. we will accept pictures
6
46%
Total votes : 13
Postby Ron Dickey » Sat May 13, 2006 2:01 pm
I put this on the gereral section but the poll is gone there
I can not replace my old bearings on my trailer. my money is limited.
I can put the body in the truck bed but the build slowed down for the trialer.
I have 2 months and will not be working on it daily
gas here in CA is coming close to 4 bucks.
Trailer had 4 prong hub Im trying to move up to 5 prong which I have tires for.
and I need a kick in the Ass as to which direction to go.
173882......173887
Ron Dickey
Images: 787
Postby An Ol Timer » Sat May 13, 2006 2:10 pm
If you have a wheel, bearing, spindle, axle setup that will work regardless of whether it's what you eventually want to end up with or not, then clean it up good and put it to work. Then when the finances recover swap it all out for what you really want.
An Ol Timer
Postby madjack » Sat May 13, 2006 4:34 pm
An Ol Timer wrote:If you have a wheel, bearing, spindle, axle setup that will work regardless of whether it's what you eventually want to end up with or not, then clean it up good and put it to work. Then when the finances recover swap it all out for what you really want.
...echo...echo...echo........................................................ 8)
Postby Dean in Eureka, CA » Mon May 15, 2006 10:11 am
Ron,
It doesn't say anywhere in the rules that you have to have the trailer done.
Tents work... Well, along with a little ribbing. :R
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Ron Dickey » Wed May 17, 2006 1:01 am
Persistance paid off I went to return them and rather then get my 50 bucks back they found the bearings.
Now onto my next crisis.
Thank you all for your help.
Ron D.
173882......173887
Ron Dickey
Images: 787
Return to User Polls
