2 Person Standy
Re: 2 Person Standy
Postby _Ryan_ » Wed May 15, 2013 8:22 am
donnan wrote:This is a really nice trailer Dan. I applaude you for the design. :applause: Thank you so much.
Is there any way to convert the measurements over to metric easily?
I may build one of these. :D
Cheers
Paul
You can do this fairly easily in SketchUp although you do have to know where to find it. Open the SketchUp model then navigate through these menus:
Window -> Preferences -> Template
Change the measurements from feet and inches to meters or millimeters.
_Ryan_
Images: 356
Re: 2 Person Standy
Postby donnan » Thu May 16, 2013 1:03 am
Hi Ryan,
thanks for the reply. Unfortunately your directions didn't change from imperial to metric.
Perhaps there is no way to do it after a model has been made in inches.
Thanks again mate. :(
Life is too short not to enjoy it :)
When I gamble I like to win.
http://www.realpayers.com
donnan
Re: 2 Person Standy
Postby Fyddler » Thu May 16, 2013 1:23 am
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Re: 2 Person Standy
Postby danlott » Thu May 16, 2013 11:04 am
Here is the file with millimetre measurements. Hope this helps.
2 person standy metric.skp
(1.25 MiB) Downloaded 253 times
The correct path to change dimensions is:
Window -> Model Info -> Units
Then select Decimal as the Format type. Then select the the unit of measurement that you want to use.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Re: 2 Person Standy
Postby donnan » Thu May 16, 2013 8:26 pm
Thank you so much Dan. You are a champion.
This will make it alot easier to build now I don't have to manually convert measurements over.
Cheers mate :beer:
Paul
ps. I tried that path and in my sketchup 8 free version I don't have "Model Info" in the path.
pss: I just took another look and the path should be "Windows/Model Info/Units". Thanks again mate.
donnan
Re: 2 Person Standy
Postby danlott » Thu May 16, 2013 8:34 pm
donnan wrote:Thank you so much Dan. You are a champion.
Cheers mate :beer:
Paul
You are correct on the right patch. I copied and pasted from an earlier post and did not delete the Preferences part. (I edited my earlier post to maybe not confuse anyone else.)
Make sure to start a build thread and post lots of pictures.
Dan
danlott
Images: 264
Re: 2 Person Standy
Postby donnan » Thu May 16, 2013 9:06 pm
Thanks Fyddler for posting that link.
I didn't see it until after I saw Dan's post.
Somehow I never received and email to tell me that you guys had posted replies. I better check my email settings are correct in the user control panel.
Thanks guys.
Paul :thumbsup:
donnan
Re: 2 Person Standy
Postby donnan » Thu May 16, 2013 10:01 pm
Dan could you please tell me what the idea of the sunken floor section just in front of the toilet.
Is it meant to be stood in?
I am concerned any great weight in there may go through the floor.
Cheers
Paul
donnan
Re: 2 Person Standy
Postby danlott » Fri May 17, 2013 12:20 am
donnan wrote:Dan could you please tell me what the idea of the sunken floor section just in front of the toilet.
Cheers
Paul
That is the purpose. If you are concerned about weight you could add some small angle iron supports under the drop floor section. That is what I decide to do on my build. Really simple to do and does add support.
97417
Dan
danlott
Images: 264
Re: 2 Person Standy
Postby djdawg » Mon Jun 17, 2013 3:57 pm
Does anyone think that this could be made as a foamie?
Kevin
Bellingham, WA
djdawg
Re: 2 Person Standy
Postby KCStudly » Mon Jun 17, 2013 11:24 pm
Yes, Foamie or hybrid foamie.
It's a great design.
Return to Sketch up designs
