5x8 design questions
Re: 5x8 design questions
Postby tony.latham » Fri Jun 18, 2021 2:39 pm
Where will your hinges be on the doors? On top?
Postby DesertApprentice » Fri Jun 18, 2021 3:32 pm
tony.latham wrote:Where will your hinges be on the doors? On top?
That is the plan. I'm actually intimidated at the thought that I need to fabricate my own doors due to the odd shape and dimension.
DesertApprentice
Images: 28
Postby eLink » Sat Jun 19, 2021 12:07 pm
DesertApprentice wrote:since one post only allows 2 attachments
The trick is to upload images to your Gallery first, then you can insert as many as you like into your posts.
Check out this link:
http://www.tnttt.com/viewtopic.php?p=911290#p911290
eLink
Images: 142
Postby Socal Tom » Sat Jun 19, 2021 1:18 pm
DesertApprentice wrote:since one post only allows 2 attachments, here is the kitchen and hatch door concept
Have you thought about having the drawer come out of the side?
Socal Tom
Postby DesertApprentice » Sun Jun 20, 2021 11:37 am
The trick is to upload images to your Gallery first, then ...
Thank you very much for the tip, eLink!
I did think about that. I'm still open to ideas.
Here is my thought: I like the idea of a hatch door in the back that can also be an entry door. A remote benefit is I could put larger items inside the trailer, it provides a limited utility function. If I do side pullout, it will need be at the front. A "kitchen" is at the front might be away from other stuff. Also the front side real estate is blocked by the tongue. Another tangential benefit of pulling out from the back, the pulling handle is covered inside the back hatch door, one less hole I have to cut on the wall.
DesertApprentice
Images: 28
Postby saywhatthat » Sun Jun 20, 2021 1:01 pm
. For the metal, the plan is 1/4 inch 2x2 square tubings for the frame
you have already lost the fight. it dose not have to be mine is bigger than yours. you could stack three full-size cars on that
I like the design you didn't get lazy and just cut one corner off
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby DesertApprentice » Sun Jun 20, 2021 3:36 pm
I noticed they are selling a 50 degree trailer coupler for the A-frame tongue. Does that mean 50 degree is a "preferred" angle for A-frame tongue? Any theory on what is an optimal angle of an A-frame tongue (if such a number exist)? I wonder what is the importance of the angle.
I roughly measured my design is about 54 degrees. Maybe I should consider adjusting it to be 50.
Thanks in advance!
DesertApprentice
Images: 28
Postby DesertApprentice » Wed Jul 28, 2021 11:27 am
One day into the build, i already got problem, my frame is not true square, seeking advice viewtopic.php?f=50&t=73997&p=1280903#p1280903
DesertApprentice
Images: 28
Postby twisted lines » Wed Jul 28, 2021 1:25 pm
50s for me.
Racking up; And Rapin foam
twisted lines
Postby Dan Gary » Tue Sep 14, 2021 8:33 am
tony.latham wrote:What jumps out at me is your axle placement. It's too far forward. It needs to be at about the 40/60 point on your frame (excluding the tongue).
Curious Tony, and mind you I’m a newbie here, but on a 10ft. box, is not the correct axle placement 48” from the rear for a 40/60 split? This drawing indicates 44” rear and 76” to the front. The diagram does show a slight offset of the axle to the front of the wheel center and perhaps that’s why you mentioned this? It appears however, according to this sketch that this build already favors a slightly heavier tongue load. I’ve started a new build of my own on a 5x10 and am in the early learning stage here. Sorry, think I figured it out, the sketch you posted was not his build but an example of a good 40/60 split as his is a 5x8 and you posted a 5x10.
Dan
Dan Gary
Postby DrewsBrews » Tue Sep 14, 2021 11:22 am
Looks like the diagram was his example of 60/40. Spindles 44" from the back on 120" frame.
Incorrect spindle placement seems to be a common issue on offroad squaredrops for some reason. Leading to insufficient tongue weight and they have to come back later and add heavy tongue box or move more items to the front. Maybe they only think of the frame dimensions, but then add the additional overhang of the galley off the back without taking this into account. Don't know
DrewsBrews
Return to Sketch up designs
