Lee's Stroller wrote:Thanks for the link. The canvas job looks really clean. So in this tread the "Mix" was 50% water and 50% TiteBond 2?
ghcoe wrote:I used a 50/50 mix when I did my canvasing. I think you will find the bond will not be real strong even with full strength glue. Some people perforate the foam to encourage a better bond. The problem is the foam is just not a great surface for glue to bond to, it usually still pulls off easily because the foam will fail at the glue line. A lot of the bond comes from the shrinking of the canvas or fabric over the surface creating a tight drum like pull to the edges. That is why you want to overlap the edges so it can pull tight across the surface rather than shrinking away from the edges. If that makes sense.With the combination of a light bond to the surface from the glue and the tight drum like effect across the surface it really makes for a tight durable surface. For it to pull away from the surface I would suspect you would have to push from the inside of the wall out and something bad has happened at that time.
Can Titebond Wood Glues be thinned?
Most of our water-based wood glues can be thinned with water up to 5% by weight or by volume. Adding more than 5% water to our glues will decrease the bond strength. Titebond Liquid Hide Glue is thinned by gently heating the bottle in a pan of warm water. Titebond Polyurethane Glue may only be thinned by placing the bottle into a pan of warm water.
IndyTom wrote:Sometimes I feel incompetent when it comes to searching. Most of the threads aboutPMF that I find, it is being applied to a foamie. I want to apply it to a plywood skinned ttt, and would love to find someone else who had done it.
