Page 2 of 2
Re: Skinning a 5x10x5 teardrop with 4x8 Luan
Posted:
Mon Jul 17, 2017 10:12 pm
by tony.latham
Thanks for the advice to get this plywood.
That's what this forum is all about. Something like
pay it forward.
Posted:
Thu Jul 27, 2017 9:46 pm
by closecuddlin
I am building my 1st teardrop. I am using various thickness of Baltic birch throughout. Its a 5 wide x 9 long box. I am planning to use 1/8 " as an outer skin, covered by a double layer of Upol brand spray on bedliner coating over the entire outer surfaces, masking off the doors, roof vent, frame rails. I'm using TB III on all wood to wood joint areas and the outer vertical edges to the roof skin . I dont like the looks of the aluminum trim molding at that area and was wondering if any one has another idea what I can do to make that seam waterproof, and if you think I should double up the roof skin by bonding a second layer of 1/8" onto the first one. ..or not? Has anyone ever heard of bedliner coating used on a teardrop? I dont mind the irregular surface and It would actually seal up what the cartridge sealer misses. Thanks...Steve in Oregon
Posted:
Thu Jul 27, 2017 10:07 pm
by tony.latham
closecuddlin wrote:I am building my 1st teardrop. I am using various thickness of Baltic birch throughout. Its a 5 wide x 9 long box. I am planning to use 1/8 " as an outer skin, covered by a double layer of Upol brand spray on bedliner coating over the entire outer surfaces, masking off the doors, roof vent, frame rails. I'm using TB III on all wood to wood joint areas and the outer vertical edges to the roof skin . I dont like the looks of the aluminum trim molding at that area and was wondering if any one has another idea what I can do to make that seam waterproof, and if you think I should double up the roof skin by bonding a second layer of 1/8" onto the first one. ..or not? Has anyone ever heard of bedliner coating used on a teardrop? I dont mind the irregular surface and It would actually seal up what the cartridge sealer misses. Thanks...Steve in Oregon
Here's a great build that was done with a bedliner product... over epoxy. I think you could get into trouble––down the road–– without the epoxy.
viewtopic.php?f=50&t=57065Tony
Posted:
Fri Jul 28, 2017 12:01 am
by ssuuki19
I just posted a thread about a very similar situation, well its on the inside, but that price is amazing even with the exchange I'd take it. Just starting looking into ordering 1/8 product of any kind and realizing the pickings are slim, retail.. I'm going to do the exact same thing and see what I can find. It'd be nice to see some pics of that Baltic Birch as it arrives..
Posted:
Fri Jul 28, 2017 7:30 am
by MarcInBoise
I did what was suggested in post #2, laying 2 pieces flat on the ground and gluing them together with a 3 or 4" strip.
I then sponged water on the back side which made them very pliable. Bending them to fit was no issue at all.
And I used gorilla glue to make the bond, which likes the damp wood.
I've had ZERO issues.
Posted:
Sat Aug 05, 2017 4:02 pm
by ditchdoctor
Where does one find 5 foot wide baltic birch plywood.
Posted:
Sat Aug 05, 2017 5:07 pm
by QueticoBill
I found it from several places in Chicago area. After several tries "baltic birch plywood 5 x 5 chicago" hit the mark. They tend to lumber stores serving the trade, not homowner.
Posted:
Mon Aug 07, 2017 9:16 am
by wingloader
I found mine at a specialty lumber yard that was only 5 miles from my house!!
I didn't know it but all baltic birch ply is 5X5. Who knew.
They had to order it from somewhere else. It took a week to get it. I couldn't believe it was only $15 per sheet. I think any specialty lumber place would be able to order it for you provided you have one within a reasonable distance from where you live. You *may* be able to get a Home Depot to order it for you but not likely.
I bought a sheet of 4x8 1/8" hardwood ply from Lowes for around $15 per sheet. But that stuff is NOT bendable.
Posted:
Mon Aug 07, 2017 9:48 am
by tony.latham
Take a scrap of that 1/8" Baltic and throw it in a bucket of water. Two weeks later it still won't be delaminated.
I wouldn't bet my wagon on luan.
T
Posted:
Mon Aug 07, 2017 10:54 am
by QueticoBill
Interestingly, the supplier near me has both 5 x 5 and 4 x 8.
https://www.owlhardwood.com/baltic-birch.html
