Page 1 of 1
vinyl graphic skins....?
Posted:
Sat Nov 30, 2013 10:25 am
by breesha03
Hi all-
I've got a little guy 6 wide that originally came from Cabelas--its got a camouflage (what I assume to be) vinyl graphic skin on the outside. The original owner left it outside, uncovered in the elements and the colors on the sides is pristine, but the top and back are completely faded out. Its also starting to peel a bit in a couple places. I have to admit, I love the real tree camo--it turns a lot of heads.
I know most everyone here does their own from scratch builds and doesn't have to deal with issues like this, bit I was hoping someone had experience with these graphic skins. I'd love to get a new one but have no idea where to start. I figure those auto graphics places would do it, bit I'd rather go with a place that's camper specific if anyone knows of any.
Re: vinyl graphic skins....?
Posted:
Sat Nov 30, 2013 1:18 pm
by jgrote
That stuff does have a lifespan. You should be able to find a company locally that does vinyl wrapping on cars, vans, and the like. They usually do wraps for businesses to advertise on their vehicles. They can print out what ever you want on the vinyl. I bet they could get you taken care of. FWIW, it is not really a DIY job. It's really tough to do and not get any wrinkles in it.
Posted:
Sat Nov 30, 2013 3:05 pm
by breesha03
Right! I have no plans of doing it myself. I guess it wouldn't hurt to call a couple auto decal places and see what they've got.
Posted:
Sat Nov 30, 2013 4:31 pm
by Oldragbaggers
Have you checked with Cabelas or Little Guy to see if either one can tell you who did the graphics originally? If the template/artwork exists somewhere then maybe you can just get whoever printed them for Cabelas/Little Guy to print one for you and then take it someplace where they do installations.
Posted:
Sat Nov 30, 2013 4:33 pm
by breesha03
Excellent idea--i hadn't thought about that because I don't think they were made very long. I'll look into it. Thanks for the suggestion!
Posted:
Sat Nov 30, 2013 6:23 pm
by jgrote
The camo print is widely available. (and quite popular) The only issue with getting it from Cabela's is that most installers will only install their own product. Partly because they make money on the product, partly because they have to warranty it. It's no different than bringing your own parts to a mechanic to fix your car. Doing an avg size car costs about $2k, but they are much more complex. I bet you could get the top done for about $500 depending on how difficult it is to get the old stuff off.
Posted:
Sat Nov 30, 2013 6:30 pm
by breesha03
Yeah, I think getting the old stuff off might be a bit of an issue. I had thought about taking it off and using something else to skin it, but I've decided its really not a job I want to take on myself. The partial skin--top/back only--might be the way to go.
Posted:
Sat Nov 30, 2013 10:25 pm
by RandyG
Hi, I do vinyl removal and reapply on aircraft tail flashes. Its not that hard to do yourself, but the problem I can see is getting the prints to size without seams. There are machines capable of doing very large but it may cost you big. If you remove all the old stuff it may save you some money there. We use a decal remover, a tool with a spinning wheel made of rubber, comes right off..You may try a sign shop, they do work with the same machines we use to cut and print on vinyl. Try to haggle them though, most of those shops charge high. Or you can put their logo on your trailer for a discount, some companies do that.
Posted:
Sat Nov 30, 2013 10:27 pm
by breesha03
Thanks, Randy! Seems like a logical idea, removing the old myself if I can. I appreciate the suggestions.... very helpful.
Bree
Posted:
Mon Dec 02, 2013 7:40 pm
by mallymal
I've got a feeling they heat the vinyl with hot air guns to apply it.
I wonder if doing the same would help soften it as you remove it? Good luck!
Posted:
Mon Dec 02, 2013 9:13 pm
by breesha03
I wondered the same thing....but the adhesive seems to have become very brittle. I'm guessing a few of these 100° summer days pretty well baked it all....heat might not make a difference at this point. :/
Posted:
Tue Dec 03, 2013 4:44 pm
by KCStudly
Just throwing out an option.
Not for sure, but some of those camo patterns are proprietary. Your local vinyl shop may have to pay/charge a premium for the use of the pattern.
Since you have the corner trim, I bet they could do the roof in a solid color, like forest green (or one of the colors in the print) and it would look pretty good combined with the existing sides, too, rather than trying to match just the roof and finding out that the side panels now look more faded than they did before.
Posted:
Tue Dec 03, 2013 5:38 pm
by breesha03
Excellent idea. I've actually thought about getting rid of the camo altogether, but I have to admit I'm rather attached to it. The sides are pristine.....that really makes the most sense from a cost perspective. Thanks, KC!
Posted:
Tue Jul 22, 2014 4:36 pm
by freddyb
Hi Bree, did you ever work out a solution for your fading camo vinyl top? I'll be tackling the same issue here soon...
