Page 1 of 1
Does aluminium have directional grain?
Posted:
Wed Oct 01, 2014 4:43 pm
by Dickie English
Hi Guys
I have a question,does aluminium sheet mill finish .08mm thickness have a grain or direction similar to wood.The reason i ask is when polishing, some areas shine much better than other areas.Should i be looking for a grain pattern or is it technique or products.
Regards Dick
Re: Does aluminium have directional grain?
Posted:
Wed Oct 01, 2014 6:09 pm
by Wolfgang
There isn't a "grain" in the material. Depending on the finish there will be a polish or linish grain. If it's been anodised don't polish it!! you'll remove the anodising and ruin the finish.
Posted:
Fri Oct 03, 2014 4:43 pm
by rowerwet
Aluminum sheets have a grain, it is the direction the metal was stretched in the rolling mills as it was squished to dimension. It will be more of an issue if you are bending it, I'm not sure about polishing.
Posted:
Sun Nov 30, 2014 10:09 am
by dmdc411
From what I remember from Aviation school, there is a grain direction it is as stated the direction the sheet was stretched into its sheet form. And it only matters for bending in tight radiuses. If you were in fabricating of structural components, a drawing or print may call out grain direction
Posted:
Sat Dec 06, 2014 3:23 pm
by Tripmaker
The doors on my TD are symmetrical, 36 x 36 with a 36" radius. When I assembled my doors, I unintentionally matched the left skin to the right door, and right skin to the left door. The result is that the grain, for lack of better term, is 90 degrees off from the sides of the trailer making them look like a different color. So yes, there is a grain.
