DrewWalden wrote:I am finding that a lot of the sources for edge molding are only selling it in 8' pieces. This is not enough material to travel from the front of the trailer to the galley seamlessly. How are you guys using 8 foot pieces to trim the edge of the camper?
Thanks,
Drew
Drew:
I start from the front of the 'drop with an 8' piece. After the hatch hinge is installed, I fill the gap in with a 30" (or whatever it is) piece. I do it this way since the top of the trim needs to be butted to the hinge while the side of the trim extends under the hinge. (The side of the trim is about an inch longer than the top of the trim.)
Sure, there's a butt joint between the two pieces of trim but it has sealant under it. In the grand scheme of things, it looks and functions fine.
