Best way to attach aluminum?
Hi, everyone
I am getting to the point that I need to attach .040 aluminum to the outside of my TD. What is the best way to attach it, in your opinion? I have 2 tubes of the fast-drying Trempro caulking, aluminum trim, and a bunch of butyl tape. I plan to "float" the aluminum (just attach the edges). My questions are:
Is that enough TremPro?
Should I glue on the aluminum first, let it dry, and then attach the trim?
Or, should I attach the trim while the glue is still drying?
Should I cut out the holes for the windows and vent before or after I cut out the aluminum?
On some people’s build journals they use about 500 clamps to hold the on the aluminum while the glue dries. I only own 4 clamps and I don’t want to buy more, if that makes a difference. FYI
Thanks for your help with this.
Bill
Bill
