FRP and NRP
I have been looking at NRP and FRP since I have run across mentions of it here on the forums.
I was considering it as an alternative to Aluminum. I like the look of it as well as the cost and ease of painting. I would love some feedback from people who have been using this as a skin.
Do you just float the NRP or FRP like you would alum.? (Tack down the edges and then apply a waterproofing glue, apply the trim, and then secure the trim?) I would still want to use aluminum trim on the outer edges because of the availability and as an accent.
Do you leave expansion gaps around the edges to accommodate expansion/contractions?
Since it's sold in 4' widths I am thinking cutting down the length to make 2.5' strip that are 8 foot long and joining them in one long horizontal seam from front to back on the main roof as well as the galley roof. Since the joints are not lapped joints the vertical seems like a better option to keep water from collecting at horizontal joint lines?
Any other key points I should look at before I leap into the install?
Here are the two products that I am considering.
FRP: http://www.homedepot.com/p/4-ft-x-8-ft-White-090-FRP-Wall-Board-MFTF12IXA480009600/100389836
NRP: http://www.homedepot.com/p/48-in-x-96-i ... 492220-_-N
Thin NRP: http://www.homedepot.com/p/1-16-in-x-4-ft-x-8-ft-Plastic-Panel-63003/202090190?MERCH=REC-_-rv_gm_pip_rr-_-100389836-_-202090190-_-N
Thanks to all of you for the great resource that is tnttt.com
