cedar fence pickets for outer skin
Finishes, paints and coatings
Postby outlaw53 » Wed Jun 19, 2019 1:52 pm
Has anyone tried using cedar fence pickets for exterior skinning. Maybe t/g the wood or 1/4 notch with the boards glued and finish nailed to the studs? Sure would like a little help. thinking of trying this I think it would look great. :thumbdown: :thumbsup:
outlaw53
Re: cedar fence pickets for outer skin
Postby scoopburt » Wed Jun 19, 2019 2:41 pm
I think it will look great and smell good. You will probably have lots of trimming to make them uniform. The ones I have used for fencing have been less than perfect when trying to but them up 1/8" here 1/4" there. Nothing that you notice on hundreds of feet of fence but will need addressed if you plan to router your own tounge and groove or other fitting method. It will sure look nice. Perhaps consider vertical board and batten. Image
scoopburt
Postby greygoos » Wed Jun 19, 2019 3:06 pm
greygoos
Postby outlaw53 » Wed Jun 19, 2019 6:11 pm
Thanks, I needed that info? Makes me feel better. :lol: :D
outlaw53
Postby Tom Horn » Thu Jun 20, 2019 10:03 am
I bought some cedar a couple days ago got them set out so they can dry out first before I start milling them. Seems like all the big box stores have is wet cedar in stock.
Tom Horn
Postby outlaw53 » Thu Jun 20, 2019 11:32 am
Let me know how it works out Tom. What size and how you fasten them, are you going to fasten straight to the studs?
outlaw53
Postby Tomterrific » Thu Jun 20, 2019 4:02 pm
I posted about using old fence pickets for a "rustic" build some time ago. In my imaginary build I used old time Jen Lind construction where the cedar is strong enough for both the siding and the studs. I would use tar paper stapled to the inside and thin ply over the paper for interior wall finish. The sandwiched tar paper would take care of any gaps between the old boards. The roof would be corrugated steel roofing, used if possible.
Tt
Tomterrific
Postby Tom Horn » Thu Jun 20, 2019 10:37 pm
outlaw53 wrote:Let me know how it works out Tom. What size and how you fasten them, are you going to fasten straight to the studs?
Will do. I am planning on tacking them directly to the 3/4 plywood skeleton with glue and nails around the edges. I also cutting them into 3 wide strips and routing overlay joints to eliminate any voids between the boards. Hopefully anyways. lol
Tom Horn
Postby outlaw53 » Fri Jun 21, 2019 8:39 am
What kind of routing, is it just 1/4 inch square with glue to lock out water? Are you going to use finish nails of a certain kind so they don't rust or does it matter? Whats your thoughts on screws instead of nails? sorry if I am bothering you to much. Just trying to do this right the first time. :thinking:
outlaw53
Postby Tom Horn » Fri Jun 21, 2019 7:10 pm
Quarter inch overlap has been my plan and the nails will be mainly used to hold the wood in place till the glue dries. Hopefully the nails will never see water as I plan on them being covered up by trim boards and in the groove of the overlap. I mainly plan on using them to hold the cedar in place till the glue sets. That's my thoughts on it so far. When I start putting them on I might change my mind and do it differently if I don't like how its going.
Tom Horn
Postby outlaw53 » Sat Jun 22, 2019 7:09 am
Oh, now I see, the nails will not show. I was thinking they would be in the facing for strength. What brand of giue are you going to use, maybe titebond lll? Let me know how it works.
outlaw53
Postby Tom Horn » Sat Jun 22, 2019 6:21 pm
I haven't quiet decided on glue yet. At the very least tight bond III.
Tom Horn
Postby outlaw53 » Sun Jun 23, 2019 6:48 pm
just let me know how things turn out!
outlaw53
Postby QueticoBill » Tue Jun 25, 2019 6:07 pm
Google "tear drop barn board" and you'll see some examples.
QB
QueticoBill
Images: 22
Postby outlaw53 » Wed Jun 26, 2019 11:39 am
Not bad quanticobill but, not exactically what I was wanting. :D
outlaw53
Return to Skinning secrets
