Sealer under dye under epoxy
I'm about to start staining. My teardrop is skinned with birch plywood, and I'm going for lightish brown color and a woody finish.
I was planning to use trans tint dyes, since they seem to have a good epoxy compatibility. Trans tint seems to recommend sealing the wood first with thinned water based finish to avoid blotching.
I can't find any information whether this will cause problems with subsequent coats of epoxy.
Anyone knows or has tried? I did some small samples and blotching doesn't seem to bad so I'm thinking maybe it's best to skip the sealer altogether, but I'm also worried blotching may be more evident on a larger surface...
